brother chris
- Joined
- Jul 28, 2002
- 2,063
Okay, I have a 1978 55hp evinrude. When I start it, all is okay. I let it run until the revs go down and then cruise. After a 10 min run in the lake, I shut it off and when I try to start it again, it won't start. The first time it happened, I figured I flooded it cause I smelt and saw gas coming out of the carb. So, I let it sit for a bit and then it started again. Yet after another 10 min cruise. It happened again. I don't know why
So, the history of the motor is: I just bought it last week off some guy who said it never ran since last year. I do understand that the bowl should be cleaned, although if it ran when I tested it, and when I am in the water, should it still need cleaning? I am not sure, so I bought 2 carb kits to do today. I hope that will fix the problem. I was hoping someone out there might have an idea. Thanks. See, it will always start, but it will only rev high. As soon as I try to slow it to idle it, it will die.
