My 63' Jupiter Resto
overboat
I have the major Starcraft bug and I have started my resto. I am posting before and some current pics.
ezmobee
Re: My 63' Jupiter Resto
Nice boat. Looks very similar to what I started with on my Jupiter project. Good luck! Welcome to the madness.
jasoutside
I really like your Jupiter there, great project!
Have fun!:D
fshngho
Welcome OB. I have bad news for you, once you get the bug, there is no cure. Would you believe some guys finish their projects and go looking for more?:eek:
"Hello, my name is Dale and I am a Starcraft addict"
Nice work so far, what kind of paint did you use?
TheWrks
Looking good, although it will look great when you are done... Good luck with the Resto'
Scott
overboat
Got some more work done on the boat. Remove carpet and found previous owner replaced floor(using lots of liquid nails), they did use 3/4" plywood but never sealed any of it. I was able to remove all pieces w/minimal damage. Underneath the new floor found some great flotation pieces(will be upgrading that). Are the noodles what everyone is using or will pink styrofoam work? Got the pressure washer out and was able to clean the inside, next will fill w/water and check for leaks. I will also be applying Gluvit. Will continue to keep u posted w/pics.
ezmobee
Noodles or the pink/blue sheet foam from Lowes/HD.
