My 86 30hp Rude Is Still Boggin Down!
dewdiggler
she starts fine, idols good, takes off at 1/4 throttle with a slight studder,
runs good at about 1/2 to 3/4 throttle, goes all out at full throttle THEN with in a minute she just boggs down to nothing:mad:
then she dont want to go wot with out a lot of slow feathering.
heres what i have done ;
checked and cleaned the fuel pump.
took the carb off and cleaned with gumout carb cleaner and i wire thru every hole.
replace the fuel line on the tank.
dumped out the old gas and replace with 50/1 mix
checked and sprayed carb cleaner thru the pickup hose in the tank.
spayed thru the hose from the
were do i look next?
what is the small hose that comes out of the primer to the top of the carb?
all ideas are very much welcome and appreciated.
HTANKS, DEW
