Yesterday after 2 hours run with cruising speed, we stopped, with engine off, for about half an hour, just outside out harbor. The last run into harbor i gave it full throttle and trimmed the drive. Just when I pushed the trim button all electricity disappeared for a short moment (my Chartplotter shut down). I throttle down to cruising speed and tried the trim again. And the same happened again. I throttle down to around 650 rpm and turned on my chartplotter again. I noticed that the it was reading 12,5 volt, and is usually 14 volt all the time from 650 rpm to 4500 rpm. I tried the trim again and now it worked without killing the electricity. But as soon as i gave it a little throttle the chartplotter told me 16 volt. I could get the chartplotter voltmeter to fluctuate between 12,5 to 16 volt depending on the speed. The built-in volt meter however did not, it stayed at 13.5 volt (it also usually shows 14 volt). The alternator was very hot without knowing how hot it used to be, but it did smell hot to.
Both voltmeter did settle down at last, showing the same and not going over 13.5 volt.
Can anyone tell what is going on and if should i be worried? Thanks.
My engine is a Mercruiser 5.0L carbed from 2001. SN 0M359543
