Re: My boat isn't fast enough
I have a 2001 Procraft 175 with a 125 Mercury engine. My top end speed is only 37 MPH. I have a 13.25 X17 aluminum prop. I have been told similar boats will do between 50 and 60 MPH. Any ideas? The engine runs stong and all four cylinders have 135 PSI compression.
Lot of possibilities that could lead to improvement in performance and many factors to take into consideration.
Motor health
Motor height and trim
Arranging the weight distribution of your people and gear
Hundreds of pounds of water soaked flotation foam in the hull
Wide open throttle RPM
Calculate the prop slip
I don't know your particular boat. Do you know of other similar outfits that perform like you say or is it hearsay ???
Post some more info and the guru's will go from there.
Welcome to iboats
