Mo1
- Joined
- Dec 11, 2015
- 76
Hello folks. A little history on this boat. I purchased it a few weeks ago it's a 1987 Capri 1400 with a Force 50 Model 507XC. Its my first boat. The prior owner said it didn't start. I brought it home prepped it for starting and noticed it didn't start cuz the laynard button was not depressed. I gerry rigged it so that the button would stay depressed and it started every time. I thought I was Mr Smarty Pants.
I then serviced the lower unit and re installed it. I turned the ignition and it didn't crank. I could hear the automatic choke coming on.
The battery is charged and the button on the laynard is depressed. I jumped the two wires that connect to the laynard switch and it still wouldn't crank
I bought a new laynard but not sure how to connect it. It has four prongs in the back. I would assume one wire to each opposite prong? On prong is labeld up. I assume that side goes up when you install it.
What and how should I test next after installing laynard? The cutt of switch at the motor. The neutral switch? I was hoping I wouldn't have to chase down an electrical problem
, The more I work on the boat the more problems I find
I guess Ill be reading the electrical section of the seloc manual..Any help would be appreciated
