northernterritory
- Joined
- Sep 4, 2017
- 69
I reassembled my 98 Volvo 3.0, hooked it up to muffes, and turned over the engine. I was anticipating I would need to tinker with it to get it to run, but to my surprise it fired up the very first time. I immediately noticed it was "idling" around 2800 rpms and killed it. I looked down the throat, and fuel was pooled up on-top of the throttle valve. Now, I did notice after the fact that i had forgotten to plug the air pressure/vacuum check port on the manifold, so I can imagine this was feeding extra air to the engine, which could have increased the idle speed, but still think the pooling of fuel on-top of the throttle valve is troubling. I didn't have a chance to try it again after plugging the port, but I will later.
The second issue was fuel leaking from the carb. I couldn't really tell where it was coming from, but maybe it was coming from the metering block contact areas? Any advice on how to troubleshoot and fix this?
I honestly am super happy to be at this point. I basically disassembled the motor down to the block, and replaced all of the bolt-on components. So for the engine to actually start, and sound like a sowing machine while it was "idling" is a huge win for me.
