Todesengel
- Joined
- Jul 18, 2005
- 22
Well, a little history about myself. My name is Josh and I am 20 years old. I lived in the SF Bay Area for 18 years of my life, we never had a boat, only did shore fishing in the Delta and some brackish water. Then I moved to Arizona after my High-School Graduation to go to college. Now we got a bunch of lakes out here, and the 115+ temps are not very fun. Recently I went back to Ca to visit my mom, and I found a boat. FOR FREE. I am not quite sure what year it is. All I have is the bill of sale, the guy said when he finds the title, he will send it to me. I believe its a 85-92, possibly older Mark Twain 16' Tri-Hull. It has a Mariner 100 outboard on it. The guy said it has been sitting for a year. <br /><br />Now the starter is toast on the engine, but all the hoses, the fuel filter, the whole engine underneath the case is beautiful looking. It looks brand new! The controls work good, but the trim switch that is located on the throttle is busted. I took a look at it, but couldent figure out how to remove the switch. I am thinking about just cutting the three wires that go up the throttle, and re-wiring them to a switch and just have my trim tab on the dash. I took the starter off, and pulled it apart. The magnets on the inside were cracked and the wires on the electric motor part were all torn. So starter rebuild is out of the question. New ones are in the range of 250-300, on ebay around $75.00. I managed to rig the trim to go down a bit, put the suction cup thingy on the intake of the outboard, and in about 10minutes of pull-starting it, it fired right up. Sounded great! Now you could physically see the motor pickup most of the water. "it wasent pouring out the suction cup thing as much", but no water shot out the little hose jet thingy on top of the outboard. <br /><br />The interior of the boat is thrashed! The only good thing left is the back-to-back seats. So I pulled out the seats, removed the little side pocket things. Not quite sure what they are called, but they create a little pocket/storage area on the sides of the boat. And I yanked the ugly grey indoor-outdoor carpet out. The wood on the bottom looked in OK shape, definitly didnt look the best. The dash is out of control ugly. The tac and the speedo do not work, and they are not even mounted evenly. The tac is like 1/2'' lower than the speedo. And there is a cigarette lighter 1/4'' from hitting the steering wheel. The Bow area looks in pretty good shape, except that it is just plastic, and there are no cushions what-so-ever. The bottom of the boat has a big gouge in it, the guy said it was just cosmetic. You can tell it was fiberglassed on the inside of the hull, and there is a little resin type substance on the outside. And the bottom of the boat is covered in this black girtty substance. Havent quite felt it yet, but its all discolored the whole bottom of the boat.<br /><br />Now for the questions. Keep in mind I am pretty mechanically inclined and want to do most of the stuff myself. Being in college and working for $6.50 and hour, I am on a tight budget. What I want to do to the boat is new carpet, new paint on the outside, want to re-upholstry everything with a pepsi blue/white color scheme. Fix the starter, install (4) 6led light bars on the inside of the boat. Install a regular car stereo in the glove box. Should be safe there right? and some 6x9 speakers in the sides of the boat as well. Possibly re-make the dash with new gauges. And mount a cigarette lighter in the back near the battery.<br /><br />Now I want to build my own seats for the bow, I was thinking a wrap around, like a horseshoe shape in the bow, and then a backing to match and mount on the side of the bow. Any idea how much vinyl will cost, and foam. I have never done interiors before, but I believe you can just get some plywood, some vinyl and some foam, and staple the vinyl to the back of the plywood and mount it? I also want to do this to the sides of the boat, those little pieces of wood that create a storage space on the side, also the control panel is mounted to these. What are they called?<br /><br />Now no water shot out of the hose when I had the motor running. Is this normal when connected to the hose? Does the motor usually have to be submerged in water? How can you tell if your outboard is overheating? Would I be better off taking the boat to a marine shop and pay them whatever to check the engine and make sure its in good running order?<br /><br />Like I said before, the trim switch is all jacked up. I took a side off the control panel, and saw three wires. I believe they were a white, a blue, and a green? Now could I just extend these wires, run them down the side of the boat, and to a threeway momentary switch in the dash?<br /><br />I know there is more, I just can't think of it right now. Here are all the pictures!<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
<br /><br />
