I replaced my impeller on my '89 Force 150 and took her to the lake. As stated in my first thread I Baxtr-ized by adding a telltale using the pics posted by Mark42 (love that blue on white boat) as my guide and used a 6 gallon portable fuel tank since I am concerned of the condition of the built in fuel tank after I drained it. The boat and motor performed better than I could have hope for, fast to get up on plane and the built in speedo says 42MPH at 5200 RPM at WOT. After about twenty minutes I check my fuel and I burned about 5 of my six gallons. Yikes!! Is this normal fuel consumption? I could also use some ideas to clean the built in tank (plate says 37 gallons) without taking apart the boat to get to it. Also my telltale does not began squirting water until the engine has been running for about 90 seconds on cold startup. When the engine is warm the telltale begans squirting right a way and very good since the new impeller was installed. I am guessing that the thermostat has to be open for mine to work. But I read thet others began putting out water in a few seconds. Any thoughts?
Thanks,
Gary
Thanks,
Gary
