ElHurrecan
- Joined
- May 25, 2017
- 15
[FONT="]
[FONT="]
[/FONT]
This will be my first boat restoration ever. I'm working with a 1972 "Hurrecan" 15 foot skiff. I could find nothing on this brand other than a riveted in plate that says "H&H Molded Products, Ashley Indiana". I'm not sure of the origins of this boat, I'd appreciate any knowledge. My guess is it is a custom boat or something that someone retitled as homemade and spelled Hurricane wrong. I like the name, it has character
The floor and transom were shot. I already completely gutted the floor and transom. I'm not exactly the term for this but the boat was designed to have a completely glassed in floor and transom. There is no water that is supposed to get in the hull. Most boats with raised decks on stringers don't function like this.
Here's where I started (click links for full res images):
https://www.boatdesign.net/attachments/img_20170426_190404-jpg.133564/
https://www.boatdesign.net/attachments/img_20170428_175410-jpg.133559/
Here's the transom and cap. There are a lot of gouges and holes on the cap that must be repaired. There was a lot of redneck goop on that cap, it took 2 days to get it off.
https://www.boatdesign.net/attachments/img_20170430_193824-jpg.133560/
https://www.boatdesign.net/attachments/img_20170506_145241-jpg.133561/
Here's where I'm at now. I totally grinded down the existing glass. Notice some stringers are broken.
https://www.boatdesign.net/attachments/img_20170520_202945-jpg.133562/
https://www.boatdesign.net/attachments/img_20170509_182450-jpg.133563/
Since I want a totally waterproof floor and maximum durability I am choosing to use Epoxy, specifically WestSystem.
Anyway here are my questions.
[/FONT]
- I quickly learned that CSM and epoxy do not work well together. CSM is designed for polyester as it breaks down the styrene binders. I did also pick up some 8oz woven. I read that you never want to use woven by itself. I was also reading about 1708 biax which is like a hybrid CSM\Woven? What type of fiberglass would you use for each portion, the floor, the transom, small repairs, and the stringers. Remember I am using epoxy.
- Notice the stringers, I'm not sure if you would call them stringers. A few of them are broken. I was going to simply sand them down a bit and glass them together. One plan I had was to place wood (a 2x4) inside the stringers to give them strength. I'm not sure if this is a good idea since couldn't if wood swells from moisture it could potentially lift the floor or crack the hull. If I am fine doing this should I coat the wood in glass to waterproof it.
- Foam or not to foam? Is it bad to just leave the hull full of air. Water is not suposed to get in there anyway.
- Any specific plywood you recommend? I planned on doing marine ply for the transom and standard ply (non-PT) for the floor. The glass will waterproof it anyway.
- I do not want to drill into my floor under any circumstances. Good idea? I plan on glassing in additional wood for me to screw my seats into. I am going to mount the center console by glassing in either wood to screw to or L brackets to screw to. What are your opinions on this?
[FONT="]
[/FONT]
