'97 Alpha 1 genII ser 0K044042<br /><br />Got home from work this evening, and it was decent weather for a change. Decided to try to get the drive installed.<br /><br />3M'ed gasket adheasive for the large outdrive O-ring and the water connection O-ring. Re-checked the engine alignment, still good, it had even spline marks in the grease, on the end. <br /><br />Drive install stoped just short of the studs. I believe it is where the splines should go into the engine coupler. I tried 3-4 times jigling the drive around and turned the input shaft a little, but no go. <br /><br />Outside of this, I might also have a shift cable issue. Even though the shift lever is in WOT forward position, the slot is still at an angle. See the 2nd picture below. There is some spring pressure pulling back on the cable. As you can see, I'm using a closepin to hold the shift cable end, not the specified merc tool. From the picture in the manual, it doesn't look like the tool pulls on the cable. FWIW, I did not have any shifting problems, clunks, or stalls, before drive was pulled for winter. <br /><br />Any thoughts, hints, or secrets?<br /><br /><br />
<br /><br />
