Hi Guys,
I bought a used Bayliner 175 (2004) that has a Mercruiser Alpha One Gen II engine - I got around to changing the prop to a Solas Amita 4 which I bought from iBoats. I am very new to this but when I swapped the props - The new prop would not spin (at all) when tightened down. It seems to be too close to the lower unit housing. I realised after some searching that there was no thrust washer, but then when comparing against some online photos, it also seems the anode is missing! After looking at some exploded view diagrams of the assembly, I cannot tell if the shaft seals are installed or not. Can anyone confirm this for me based on the attached photo? Note: I have not removed anything except the prop that was on there.
