I bought a 1987 Wellcraft Elite last fall. I never looked at a boat before but I read a lot to see what to look for. Two things I read about were soft floors and stringer rot. When i went to get it I looked over the boat for hours and couldn?t find anything majorly wrong with it. I think I finally came across something. Behind the back seat of my boat is a flip top engine cover to expose the engine, on either side of the engine are boxes for storage screwed to the floor. When I inspected the boat I checked the floor for soft spots and tried to inspect the engine mounts to the stringers. The floor is solid. The boxes blocked my view to the engine mounts. Last weekend I removed the storage boxes so I could get back there to install a fresh alternator and new spark plugs, wires and hoses. As I was hooking the port manifold hose up I noticed that the engine mount seemed to be pushing the glass on top of the stringer down, it looked depressed. I looked at the starboard side and it looked straight. I went back to the port side and decided to unscrew one of the two lag bolts holding the engine mount to the stringer. It came out easy, when I put it back in it just kept spinning. Son-of a *****, stringer rot. I did the same with one of the lag bolts on the starboard side and it came out tight and snugged back in like it should. Well, at least it?s just one side. So I have to yank the motor and have the stringer professionaly repaired. I don't have means to hoist the motor entorely out of the boat. My engine hoist could only get it up a few inches at most. I guess I have to bite the bullet and have a shop yank the engine. I wanted to put a 383 in it but I dont have the money and wont for another year. Damn if I could only get one season out of it before I was going to swap the motor anyway... Then when I got to work I noticed 4? wide slats of ?? steel. That engine mount is adjustable in height. The stringer runs about 36? from the back of the back seat to the transom. What if I take home a 24? long piece of this steel, drill and tap two 5/8 holes for the engine mount. A couple of thru holes for lag bolts. Suspend the engine with my hoist and run this plate in between the engine mount and along the top of the stringer adjusting the engine mount up ?? to compensate for the plate. Thread the 5/8? bolts into the tapped plate and secure the plate to other areas of the stringer assuming I find spots with good wood to sink the lag bolts?
Have you ever heard of such a repair or should I just shut up and yank the engine a season early? See the attached pdf I sketched up of my idea?
