Re: My idea of foam replacement
I considered coating the foam with epoxy, but the added time and expense was not worth it to me. The old foam that was in the boat was white and was dry. I had no leaks in the boat prior and I am not worried about it absorbing water.
The great thing about wire cutting foam is there is no mess, you must deal with toxic smoke, but a fan takes care of that. An electric bread knife, or a saw would make one hell of a mess ( with white foam anyway) and you are limited to cutting the width of the blade, not to mention lack of accuracy. If you measure carefully and make accurate templates, you will have precision foam blocks. One drawback at least for me, was that it was time consuming to do an accurate job. One block took me about 4 hours
( rediculous I know), but I wanted it to turn out right, as I had no extra foam. I even had to glue some scrap blocks together to make some of the blocks.
