Wow, what an awesome site, I have learned quite a bit reading the posts here.
So I was given a Privateer with a 98 40 HP Force that has been sitting quite a while, I shot some oil in the cylinders and cranked it up. I could only get it to run with my hand as a choke so I pulled off the carb and remarkably the inside looked perfect. I shot some wd40 through the passages, reassembled and replaced the dry rotted fuel lines. Cranked right up and idles perfectly.
I took it out for a test run and found it dies under load. I ran it for about an hour at 1/8 throttle and it never cleared out, but did run well albeit slow..
So I am going to order a fuel pump kit, carb kit and impeller. I was wondering what part number iboat carb kit I need for a sn: 0e332474 ?
I didn't check the inline filter in my rush to try the boat out, but I am going to replace it with a see through. It just occurred to me it could very well be the cause of my problem...
Another question I have is, how much lube does the lower unit hold, and where are the fill and drain holes?? The vent is clearly visible to me but that is it.
Last question, I realise this motor is probably small for an 18' boat,
I have seen talk that the 40/50 are the same motor besides the carb, so I was wondering if anyone has changed the main jet in a 40 HP for this one from a 50 HP (1399-6249 --JET-Main Fuel (click here) (.096) (0 - 1500 FEET))? http://www.mercruiserparts.com/showParts.asp?inbr=2532&bnbr=6&bdesc=CARBURETOR - 50 H.P.
I am thinking a few extra horses won't hurt for the $4 the jet costs...
Thanks for reading my long post!
