Hi guys finely switch boats and picked up a 1993 21' Pontoon with a 1993 60 Johnson, it has been converted to pre-mix.
Have a couple of questions thought you could help me with.
At WOT the motor is only running at 4000 RPMs(around 15mph) I was reading and it appears this motor should be running 5000 Min and 6000 Max at WOT. Any reason you can think it is only running at 4k? I will need to check the prop but the boat runs really good pushes thru the water nice.
Starts right up and runs smooth.
The second thing is I have a water pressure gauge but it is not connected to the motor. From what I read I should be able to just install a Tee connector right before it comes out of the cowling and connect the hose going to the gauge?
Other than that I finely have a boat that starts when turning the key the first time ....lol
Any info you could provide would be appreciated.
