No such thing as a 'pre-Alpha'.
That is a MerCruiser-1 (MC1 for short) drive shaft housing (upper) and the gear housing (lower) is either an 'R', 'MR' or 'Alpha One'. To determine which gear housing, you need to spilt the drive and look at the top of the lower drive shaft. If it has a spring loaded pin in it, it's an 'R', no pin it's an 'MR' or 'Alpha One'. The only difference between the MR and Alpha One is the name (marketing)...
And it's all mounted to a very very early MC1 transom housing.
Chris...
