Hi!<br />Last trip the engine broke, i had just put it in water and drove for about 500 yards. It was like it went in to neutral, the engine reved but the prop did not spin.<br /><br />I killed the engine and checked forward/reverse/neutral by spinning the prop by hand and it feelt ok. Started the engine again and tried to shift, nothing happens (except engine starts to rev more). First i thought something happened in the gear box so i took it of yesterday to check.<br /><br />Emptied the oil (looks a little brown, maybe water...) and checked the magneto plug, seemed like normal amount on it. Tried the gears and felt for backlash and it feels ok. Turning the drive shaft turns the prop both in forward and in reverse. That tells me that there is no problem in the gear box, I am wrong?<br /><br />Any idea what the problem is then? Think gears ar ok, prop seems fine (rubber hub looks ok). Engine starts and sounds fine.<br /><br />Where should I look now???<br /><br />Would appriciate any thoughts.<br /><br />/Bjornis
