dingbat
- Joined
- Nov 20, 2001
- 16,331
I went over to adjust the cover on the boat this weekend and found a mysterious crack on the side of the lower unit. The crack looks like an inverted J about 2 ½ in length that is back about 5 back from the front, (prop end) and 1 ½ up from the CL of the prop. The crack does not appear to be leaking at this time, at least at atmospheric pressure but the inside of the j is about a thumbnails thickness above the opposing surface. <br /><br />I know Ive not hit anything and LU unit still seems to run fine so Im kind of at a loss. I guess the question is has anyone seen this before and can this be repaired by welding.
