1997 mercruiser 5.7 with MR drive. I replaced 70's era 351 Ford Winsor with chevy 350 and outdrive was on in storage for about 6 months. Did not have a problem with it leaking when it was on the boat with the Ford engine. Here is my question. I thought for sure it was leaking out the propeller shaft seal behind propeller but after removing it I had no evidence of where it is comming out from. No evidence of a leak between upper and lower unit seal and the only place I see oil is from oround center part of propeller and down the skeg on to the concrete below. outdrive is in down position and has been for a while while I was timming and tuning new engine. Can anyone narrow it down to which seal this is? Thanks for your help in advance--bradeyj
