Re: Mystery Engine
Okay, time to clear this up.... The '55 25hp was VERY different from the 1954 & prior model 25hp, which would explain why your recoil didn't fit, eithe that or it's from a late '60s or later 25hp. The block serial is 1956 30hp, while the clamp serial is '55 25hp. The main differences aren't visible from the outside, as they made changes to the inside to gain the extra five ponies. The '56 30hp has a 6:1 compression ratio, while the '55 has a 5:1 compression ratio. The cylinder head dome and the piston domes are different to account for this. They also changed the wrist pin bearing arrangement, and made the intake holes on the reed plate a hair bigger. These parts are all interchangeable as a unit, .ie if you swap '56 pistons into a '55 block, you need to swap the head, too...<br /><br />With the proper bracket for the starter, it is quite easy to convert a 6V system to a 12V starter system. The choke solenoid need not be replaced. The best way is to use a '57 35hp electric belly pan with the nifty little plug in the side to get around the cables exiting from the hole in the belly pan on the '55/'56. The electric start flywheels are interchangeable as the ring gears remained the same.<br /><br />The '56 30hp is a very robust powerhead and will take a fair amount of abuse. I've run several over the years on a 36-class Utility - and have run it quite hard. On a light hull, there is a noticeable difference between the 25 and 30.<br /><br />Have fun!<br />- Scott
