My '92 5.0 Alpha evidently leaked lube and locked up & stripped gears (Grrrrrrr) I had a certified Merc mechanic replace the gears, ect.
The next season the lower was fill with fresh lube. After about 4 hrs use.. it was next to empty! The mechanic did a pressure test and found no leaks?? Where is the most common leaks on these?
I'd like to install an AFTERMARKET gear oil reservoir kit (1/4 the price!). Does anyone have a source? The only place I found is sold out.
Thanks in advance
Thanks in advance
