Woodonglass
- Joined
- Dec 29, 2009
- 25,929
A good Read...
New Boatbuilders Home Page - Boating and Boat Building Myths
I like the Myth about foaming in a fuel tank is a death sentance for the tank, it's quite obvious this guy doen't know what he's talking about and needs to do some more research.
We all know that if we take care of our boats and keep them covered or garaged our foam won't get wet and we don't have to worry about stuff like wet foam corroding our fuel tank.
Fuel tanks can also be painted before foaming them in to prevent corrosion and extend the life of the tank.
Anyone that's interested in what destroys a below deck aluminum fuel tank and what you can do to extend the life of your tank should read this:
http://www.uscgboating.org/assets/pdf/recalls/BSC79.pdf
Ok so after reading your link JNG seems the best thing to do is keep the tank high and dry.....not to trap moisture between the tank and any contact surface... If you don't let water sit on it it won't rot.... I would think that the less contact the tank has with anything other than air would be best.... Without the proper prep foaming a tank in would do more harm then good.....back yard DYIers are more likely to foam it in incorrectly and have failure sooner than if you just applied plastic strips to the bottom of the tank with 5200 so water cant get between the strips and tank and left ample air space around the tank so it can dry quickly letting the aluminum do it's job as a self protecting metal. My conclusions are from reading the last paragraph on page 4 of your link.
.. and you would think that someone blogging about boat building myths would realize that.
Yes, I also noted that myth, and would agree that it is a controversial topic, based on my first hand knowledge of replacing my tank. I see that the problem with foamed in tanks is a result from insufficient design on the builder's part. The moisture that results from the typical daily condensation cycle has no place to go and eventually settles into the foam at the bottom of the fuel bay, providing a source of moisture for the tank.
the builders generally provide no escape route for moisture that collects at the bottom of the fuel bay. This not only impacts the tank, but also effects the main bulkhead that separates the engine compartment/bilge, causing it to slowly absorb moisture through the polyester resin. The main bulkhead eventually feeds the moisture into other structural components that are in contact with it, such as stringers, etc.
So, structural issues and tank issues usually go hand in hand . . . Based on a boat's designed-in ability to retain moisture in the fuel bay and other areas.
The main thing about below deck aluminum fuel tanks is that they're not an "install it and forget it" item, they require periodic inspections and maintenance... and full access for inspections and maintenance.
Doubling the tank thickness extends the life span by 8x... so how long would a well painted double thickness tank last?
When I pulled out the fuel tank on my Formula 242 after 21 years of age the foam was still well secured to the walls of the tank. The most significant areas of corrosion were where the tank was butted up to a 2x4 wood spacer and the aft 1/3 of the keel line of the tank, where moisture had settled in the foam. All other areas of the tank were pristine.
