Re: Name that goop
I've seen it before and have dug it out but have no idea what it originally was called, I've also seen something similar that is silver in color. I've seen both sealers on really old rain gutters too. I had an older DuraCraft row boat that had it at the rear transom seams, I at first thought it was old paint that never really cured, but it was inbetween the layers of aluminum and the rivets. On that boat I had drilled ground off all the rivets, removed the transom and used a fiberglass abrasive wheel to clean the area up. On that boat, I welded in the new transom panel since the original was too badly damaged. I ended up cutting away the area that had the two rows or rivets all the way around the outer seam and I bent up a new rear panel to fit in place of it and welded both the inner and outer seams. I also made a double thick reinforced panel near the top to clamp a motor too with a replaceable outer wood panel for wear protection. It was probably overkill, but it will last forever. That was 8 years ago, and as far as I know it's still being used today. The original damage was due to it being left full of water and left out to freeze.
