Nav and Anch lights
stinger222
Just boat a Chap 2550. It has a 3 position light switch, off/nav/anchor
With Nav setting, front running lights are on, but only the front half of the pole light is lit. Anchor setting, the front lights go out, and the entire pole light front and back lights up. Is this wired right?
The stern light bulb is out so I have no idea when it lights up.
jerryjerry05
Re: Nav and Anch lights
At anchor you should have an all around white light.Underway the front R/G and the rear light on the transom should be on.The top light shoud be on in the front underway. Replace the bulb and it will be legal.Jerry
Ayuh,.....
So what's any of this got to do with I/Os or Engines,..??..??
Don S
Moving to electrical forum.
