Nav light wiring
threequez
Replaced the DTDP switch for my nav lights. everthing is wired correctly (I think) but all I can get to work are the port/starboard and transom light (not the forward light) when up and all round light (anchor light) when the switch is down....the forward light will not light. can this be the switch?
thanks
tbear1964
Re: Nav light wiring
I replaced mine 2 years ago (wrong one installed) Someone gave me this "schematic" and it worked perfectly.
It is a 6 tab switch DPDT as mentioned
1 2
3 4
5 6
connect 1 and 5 to anchor light wire
connect 3 and 4 to power wire
connect 6 to nav light wire
You may need to buy jumper tabs to make the jumpers for 1/5 and 3/4
I made my own jumper wires.
threequez
the wiring on the original switch was completly different......I will give this one a go thanks alot.
julio
Silvertip
Here is the wiring (one way to do it) for a typical nav/ancor light system.
