Nav. Lights
Re: Nav. Lights
Ayuh,... As long as they're the right color,+ project the light as far,+ in the direction Required,...
I don't see why Not...
Silvertip
Re: Nav. Lights
That depends on how you mount them. If you put one on each side, NO! Because you cannot see either one from dead ahead. If you mount them on the front, NO! Because you cannot see them from either side. Read the nav light requirments as it specifies the angles these lights need to be visible from. I would suspect they would be OK if you mounted them at a 45 degree angle at the front corners of the pontoon.
rcl700
Re: Nav. Lights
Thanks. I did not think of the viewing angle. Front & side.
