I have a 2002 Triumph 210 and my Nav lights (red and green separate) have been burning out the bulbs one at a time about every third trip. However, not, neither of the red or green light, lights up.
My Nav Switch is a double pull, double throw (in the up positions, it turns on the green, red and the 360 light...in the down position it only turns on the 360 light...middle position is off). Below my switch is a 5A breaker button.
When I put it in the switch in the Down position, the 30 light works fine. In the Up position, it keeps popping the breaker button.
Could this be a faulty Switch?
There are only 2 wires fed to my bow, but it is a pain in the #$%^& to re-run them, not including having to by pass the wire harness connector. I have checked all the connections/splices and have redone them, but the main wires I have not changed. I am hoping it is a faulty switch if you know what I mean....
Any Help is Appreciated...thanks.
