Navigation Lights (which Battery?)
buckrut69
Which battery do I hook mt lights up to? The cranking battery or the deep cycle battery. DO I need some kind of regulator or can I hook it directly to the battery with a switch?
Paul Moir
Re: Navigation Lights (which Battery?)
The deep cycle one. <br />As long as your nav lights are 12v and your deep cycle battery is 12v, you do not need any sort of converter. But a fuse between the battery and switch is manditory. A 5A fuse will cover whatever sort of nav lights you attach and protect the wiring.<br />Good luck!
