Hi Guys- I would like to run something past everyone here. Late last summer, my 1985 Johnson 235 overheated and blew the head gasket on the starboard side of the motor. My mechanic took care of it. The head was machined, but otherwise ok. As a precaution replaced the other head gasket as well. He mentioned the water diverters on the overheated side were damaged and repaired/replaced them. Also, new thermostats in the process. Yesterday, I was cleaning up some things and flushing the motor. With the cover off, I noticed the starboard side (side that previously overheated)) was hotter than the port side. It was not an instant condition, but didn't take along time either.I could hold my hand for about 10 seconds on the cooler side and only about 3 on the hot side. I was putting my hand directly on the thermostat cover. Warning buzzer never went off. I removed the thermostat completely from the hot side and retested. It all felt fine. My mechanic suggested removing the guts from a thermostat and replacing them, effectively leaving the thermostats in a "stuck open" condition.
He went on to say that doing this rather than no thermostat at all, allows the water to remain inside the motor long enough to actually cool it, while in some cases with no thermostat, the water doesnt cool the motor at all because it passes through so quickly, particularly on the exhaust side.
So there's my question- Anyone else feel this way? I had always thought with no thermostats, the motor would never reach operating temperature, and cooling would not be an issue. I'm in South Florida where water temperature, particularly now, is running about 80 degrees.
Thanks for any info and opinions.
