KCKracker
- Joined
- Jul 28, 2008
- 291
i am in desperate need of a wiring diagram WITH one wire alternator and not a voltage regulator (it does get removed right?)
also, my engine harness gets hot when the key is on, i found the coil has +12 on both posts, i thought one side was negative? even if i disconnect all wires from it except the one from the ignition, both still have +12 volts with nothing going to the - side of the coil
