Re: need a lil help
If it is on 3 blocks(two rear corners and bow), you slide the trailer under it until the cross member hits the bow block. Now jack up the bow, in front of the cross member and reblock it. Now slide the trailer under until the next cross member hits, and repeat the process. Safety is utmost. Take your time and make sure the jack and blocks are on flat ground and are stable. When it is all the way on the trailer, drop the tongue and remove the rear blocks.
