Need a little help 150 evinrude intruder lower unit
bass482991
Can someone plastic a video of how to break down the gearcase and install new seals my oil is running out on the ground
Crosbyman
this help ?
search utubes lots of videos on everything post your year and mdl ## !!!!
bass482991
after you have removed the Propeller shaft housing how do you remove the prop shaft?
Faztbullet
Have to pull pinion gear and driveshaft...why you wanting to remove if only seals?
bass482991
Just to check the gears . I found out how to remove the reverse gear and it was fine . I think that the “ o “ ring was bad that’s were the oil was coming from. I hope this works
Reverse does not do a lot of work.----It is almost always fine.-----Remove nut on bottom of driveshaft and remove driveshaft.----Then push shift rod all the way down and remove it.----Then pull out propshaft.
