David Stone
- Joined
- Nov 4, 2008
- 16
I'm trying to finish up a total rewire on my 18' Action Craft flats boat. I have dual tanks in the bow. I know that the pink wire is sender, brown is ground from each sensor. I am running the both grounds back to common ground on fuse block under console. I have also run both pink "sender" wire to the console area. Now I could use some direction. I want to use a switch (left or right tank) that is wired to my fuel gauge. The gauge has ground "G" (which I have sent to common ground on fuse block), "I" which is hot going to ignition switch, and "S" which should connect the guage with the wire coming from the (left/right) switch.
Could someone please confirm the type of switch I need (I assume a 3 prong) and to which prongs I connect the separate pink "Sender" wires and from which prong I run a single wire from switch to "S" on guage? I greatly appreciate your help as I try to finalize this project.
