Sorry if some of this is a repeat of my "need help identifying my prop" thread. I got it ID'd so I thought I'd start a new thread about the replacement.
Boat is a 1981 Mark Twain V-Sonic 170. 17ft, V hull, heavy for its size from what I've read.
Motor is a 1982 Johnson 115, 2:1 gear ratio.
Prop is/was a Michigan Wheel model 011001. 3 blade 14" diameter, 13 pitch.
http://boatpropellers.iboats.com/Jo...101654&**********=128882041&*******=996617342
I want to replace the prop because it is damaged, likely beyond repair.
At WOT, the tach shows just under 6,000 RPM, the speedo shows just under 35mph. I didn't have my GPS handy to verify the speed. From what I've read those RPMs are a little high for the motor. (should be <=5500)
The vent plate on the motor sits just below the hull, maybe 1/2 to 3/4 inches lower. I don't have any pics available at the time. The motor is mounted on the lowest setting.
Questions:
1. Should I change the size and/or pitch?
2. Any recommendations on a replacement brand/model?
Thanks
Questions:
Thanks
