Re: Need a Owners Manual (or copy) for 96 112 Johnson
The Model Number please......<br />The Model ID number is essential for us to ID your engine, see below to locate:<br /><br />For Johnson and Evinrude outboards, check the following locations: <br /><br />-the stern mounting bracket <br />-the freeze plug <br />-the flywheel <br />-the side of the cylinder assembly <br /><br />For OMC Stern Drives: <br /><br />-the nameplate attached to the rocker cover <br />-the front and/or the rear of block, behind or in front of port cylinder head <br />-rear of block, port side, below manifold <br />-the starboard side, above the starter motor <br /><br />Hope this helps.........<br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man <br /><br />
