need a piston for 1977 evinrude 85 hp
khrhunter
need a piston for 1977 evinrude 85 hp. broke a ring and it scarred the piston and not the cylinder wall thankfully. So because of money issues im going to hone and rering but need 1 piston. It is a stock/standard piston. Thought someone might have one left over from a true rebuild. Thanks
mnmfors
Re: need a piston for 1977 evinrude 85 hp
I have a powerhead with good compression, but no electronics or carb. If you are interested, email me at mnmfors@aol.com.
Dhadley
If you are going to buy a piston and ring set (the expensive part) you may as well bore that cylinder (cheap part). I bet if you measure the cylinder, it needs boring anyway. <br /><br />Good luck!
