Need a prop for 9hp Ted Williams Mod# 574-59740
egibsontx
Doing a bit of cleaning and repainting of prop revealed a crack. Also has some wallowing out of the hole where pin holds prop on. Ebay is an as is on all props I see there and cant tell if the same with the pin hole exists. EDIT
Thanks.
narwhals
Re: Need a prop for 9hp Ted Williams Mod# 574-59740
you can try this place 'marina services' out of phoenix arizona, 623-703-0393. it might take them a few days to get back to you,but they did mention having older parts for the eska's and some other off brands of motors. hope this helps you. i didn't know if your model was made by eska or if it was a force. good luck in your search.
egibsontx
Hey thanks narwhals, give it a shot. Im restoring a Ted Williams 9hp(Mcculloch). I have resurrected a 7.5hp similar to the 9 but its weedless setup and is branded Elgin Lowboy(Mcculloch as well). Neat engines but a pain to work on at first as most advised me. Didnt stop me from getting this 9hp and probably more down the road.
steelespike
A prop shop can probably weld it up good as new for you.
M
mrcrabs
Guest
I know a guy how has a barn full of Mc props and parts...I thru one in the pile a year or so ago...if you don't fix it or find one I can see what what we have, I'm not sure but a 7.5 might be the same. I would get it fixed and tuned up like SS said
