Need a source for a Sea Ray Table mount
Dirty Dawg
Hello all, Happy holidays to all of you and your family. Thank you all for the help this year with our first boat! Greatly appreciate all the wisdom and knowledge shared here.
Need some help with my 2000 Sea Ray Sundeck. I am trying to find a Internet source for the Aluminum table mount bracket that secures and bolts to the stowaway tables and grips the poles. I want to mount it to a barbecue to the pole instead of the table but I do not want to use the existing mount .
It seems that you cannot order any parts thru Sea Ray on line and must do so thru a dealer in person, is this correct?
Does any know who was the subcontractor for these tables and a possible source for the bracket? ( will not have access to the boat until 2 weeks)
Thanks Ike
QC
Re: Need a source for a Sea Ray Table mount
You could check here
QC
Agree ^^^^
Dirty Dawg
Hey all, first place I looked was on Iboats, but No pics on some of them so not sure what is what. I have include a photo of the mount on the back of the table.
Tashasdaddy, I agree about cooking over the water but my boat has no rails on it to mount. Do any of those mounts allow mounting to a line cleat, but then I would loose that use of that cleat.
The only other solid anchoring point is the ski tow bar that is over the swim platform. However not sure I want it by the engine and block the platforms access.
Any thoughts? Thanks Ike
mphy98
try kendor boat supply in franklin wi, or greatlakesskipper.com they are part of the same but in racine wi. if you ever need anything ever for a boat, i mean anything from wiring harnesses to a horn, they have it either nos, or bankrupt dealer stock. if you ever get to franklin wi, just wander around the place, you will be amazed. there is nothing i haven't seen there, even a complete fly bridge once. i know we need to support iboats, but sometimes they don't have the obscure stuff. kendor does.
Dirty Dawg
Thanks for the leads all, unfortunately Greatlakes have the base, like others, that goes into the floor but not the base that goes onto the table.
Tashasdaddy, those mounts are plastic and would not survive being mounted to the Barbecue. I would still like to find away to mount it over the water as suggested. Will have to stare at the boat and see if there is another mounting point. Ike
