Need a wiring diagram,.....Originally posted by dricouard
I'm new to the forum. I have the same engine as monkfe, but I'm having an issue not getting power to my fuel pumps when the ignition key is in the on position. If I turn the key to start the starter will crank but the engine will not start. Luckily I have twin engines to help with trouble shooting. It appears that with the key in the on position I'm supposed to see 12v at pins 22 and 32 on the J2 connector at the ECM but I'm not getting voltage there. I'm having difficulties finding a cable wiring diagram for my engine where the wire colors to pins match. Without a good diagram I will have to start stripping the cover off my harness which might prove to be difficult due the way it is routed. Does anyone have a good wiring diagram for the Volvo Penta 5.7 GSI? I have the supplement to 7743244 but the pin locations do not match what I have on my motor.
Thanks
Dave
Ayuh,..... Welcome Aboard Dave,..... Now you have a brand new thread, All yer own,.....
