boatin-on-cherokee
- Joined
- Apr 14, 2008
- 37
I have purchased a Hummingbird 525, and once out on the water - it works fine for a few minutes and then the depth goes and if I am in 100 foot of water - it tells me 1.2 feet. And then I have to turn off and turn back on, and hope it reads correctly. This unit is brand new out of the box. Before I drive an hour and return it to Bass Pro, I was hoping to resolve this with a simple solution. The only issue that I can think of that would cause 'depth reading' problems would be the placement of the transducer. Right now, it is placed at the bottom of the hull, right next to the bilge pump. The issue that I realized is this " when I placed the transducer there with silicone as its base, I placed probably about 1/4 to 3/8 thickness of silicone underneath the transducer itself". Could this be my issue? Does it require just a small, thin layer to adhere to the hull?
Any advice would be greatly appreciated. I have used this forum before I have always got reliable info.
