skidooseadoo83
- Joined
- Apr 5, 2012
- 32
I have a 1995 Blue Water Pro Am, 20.5 ft., 7.1 beam direct drive with a 1:1 Velvet Trans. It has the 300 hp 350 Merc in it. What I found lookin around was 4600-5000 RPM at WOT. Right now Im running a 13X13 1"bore 3 blade brass prop.
I only got to play with this boat a couple weeks last summer in Oregon, didn't have much time to get it dialed as far as the surf wake, got close. Needed more ballast (only had two 400lbs sacks, some lead, and a manual surf gate) All that aside, I was having trouble maintaining a semi plane state if I went any lower than around 12 mph, surface conditions aside. Lower than 12 and it would stop plowing and plane out. Of course any faster was too fast to keep up with the wake when surfing. In addition to more ballast that I will add this year, Im pretty sure I need a different pitch prop. Anyone out there knowledgeable or have experience with this kinda stuff? Any help would be much appreciated.
