Need advice on Buying an Engine
AtlDawg
I am looking at a 1985 Johnson 140 model J140TLCO. Is this a good engine or does anyone know about any problems?<br /><br />Thanks,<br />Cliff
Dhadley
Re: Need advice on Buying an Engine
A torque monster. The 1985's came with a V6 style gearcase so you can use a large diameter prop. <br /><br />A darn good motor in my opinion.
AtlDawg
OK Thanks... Sounds like I might need to go for it.
JB
Moving to General Outboard
shade788
Is the engine currently on a boat? I would ask if you could take it out for a ride. I was lucky enough to do that when I purchased my outboard. I felt more comfortable taking it out for a long ride before making the purchase.<br /><br /> :)
AtlDawg
The motor is not on a boat but he says we can run it with muffs. He also doesn't have a compression check but says that i can get a mechanic to test it or I'll take my gauge with me. The thing is it's a really good price and I was looking at a new powerhead for my 150 Evinrude. This would be a lot cheaper and I could part my rude out.
Rmac
Someone has one on e-bay right now for 800$ in Tampa
AtlDawg
That's exactly the one and I just bought it. Any thoughts from the pics/description.
AtlDawg
Also can anyone recommend how much to check on this engine? If compression is OK and it runs smooth should I just put a water pump on and go? Or should I fork out for a set of head gaskets and take a look at the cylinders?
quantumleap
If it ain't broke, don't try to fix it! :cool:
