KnotConnected
- Joined
- Aug 15, 2012
- 221
1994 7.4L Merc BravoIII . Starts with some priming & coaxing when cold. Starts right up with a tad throttle when warm. Will run if i give it throttle at ~1,000 RPM, but if I back it down to 800 it runs rough, and if I back it down any below that it'll die quickly.
I just replaced all plugs with new AC Delco MR043T @ 0.035 gap, added 2x 16oz bottles of SeaFoam to about 80 gallons of gas (gas that was added last Fall before putting her into heated storage. No additives or stabilizers were added to the gas), and sprayed half a (large) bottle of carb cleaner through it. Now it seems to run smoother at ~850-1,000 RPM, but still dies below 800. ALSO, since doing this, it doesn't die instantly, but sputters and fires sporadically until it finally quits (I swear it was firing on 1 or 2 plugs for a good few seconds before it actually died) .
Didn't have this issue last fall, and i DID have it out once this spring for an hour or so, running well (up until the end, when it died out in idle twice, then I decided to bring her in)
any suggestions of what to check / do next before I call in the pros?!
thanks!
thanks!
