BeerBrewer
- Joined
- May 1, 2010
- 13
I need a little advice from you folks. I've always wanted a boat, but never had the time. Now I have the time and don't have a lot of money! Any way, I stumbled on to a 1979 Grady White Chesapeake Cuddy (I think about 21'-22') with an OMC I/O and it needs restoring. The Hull seems okay, but the owner says the motor is toast. I haven't done a real close inspection (I will) on the Hull. The boat is basically free, but I need to buy a trailer. Assuming the hull is basically sound and everything mechanical (engine, out drive) needs replacing......is this boat worth restoring?
I'm real handy with wood work and I've done fiberglass work. I'm not what you'd call a motor head, but I have assisted friends rebuild their engines.
Your help is appreciated!
