Need an exhaust snout for an 89' 125hp Force
MikDee
Banned
Just as the title suggests, anyone know where I can get one? reasonable.
roscoe
Re: Need an exhaust snout for an 89' 125hp Force
Mercury dealers sell them pretty reasonable, or keep watching ebay, maybe for months until one pops up.
Bigprairie1
MikD
...this is a spare one I have off a cracked lower unit. The motor is a 91'/90hp...would this work? (note: I'm not sure if they are different between the 125hp or 90hp units?). Regardless, this is available.
Let me know or send me a PM.
Delta 1
Are you looking for the part pictured or the one that bolts directly to the bottom of the motor and feeds into the midsection?
MikDee
Banned
Thanks for the replies, It is just the snout that bolts to the cavitation plate that I need.
Big Prarie, I don't know if that will fit? it looks slightly different than mine, I notice you have a 1991 model, with water intakes above the prop, mine has water intakes in front of the prop? guess I could start checking part numbers, and let you know.
Bigprairie1
MikeD...if you measure up what you've got I will check it against this one.
There seems to be a huge amount of standard parts between the 90/120/125hp motors so that might include this snout item?
Anywhooo, just let me know.
MikDee
Banned
Check your PM
Delta 1
If his won't work for ya I have one off an '89 125.
