Need Baseline Prop Advice
chh777
Boat: 1980 McKee Craft 17' Southporter
Motor: 1977 Evinrude 85 hp
I recently acquired this boat and the motor had a Chrysler SS prop on it. It is not a thru-hub exhaust prop and it seems a miracle the motor wasn't burned up. The previous owner must have never run it with this prop. I removed the prop and started the motor 1st try. Good/even compression across all cylinders. I've ordered a water pump kit and Vernatherm for standard maintenance. Will be going through the carbs as well.
I haven't splashed the boat yet so I have no baseline (RPMs, holeshot, top speed, etc.) Can anyone recommend a prop for this setup for starters? I prefer to err on the side of caution and I'm not interested in achieving maximum speed. I will be buying a spare so I can make adjustments with that prop.
SkiDad
I agree 17 would be a good start - what pitch is the chrysler prop.xxxx
chh777
Thanks for the responses.
mitzysman: The lower unit is in the shop getting the skeg straightened. I'll reply with details on the Chrysler prop when I get it back.
dazk14
Ensign
As noted above.
Here is your prop... Solas Rubex $109.98 13-3/10" x 17" pitch will be a very nice cruising prop... or non-rubex for $10 cheaper.
It included the thrust washer, spacer and the Hub kit. The Rubex advantage here is you can get a barebones rubex replacement prop for $70 delivered without the hub, about what a repair would cost you.
If you expect more than light load cruising, then the 15" pitch version would help with load carrying abilities, water sports, acceleration, etc.. A 15" 4 blade is suitable as well for load carrying,water sports, lower planing speeds for rough water and better tracking.
I know Mckee's are tanks, but can also absorb water, like any whaler style.
SkiDad
Rule 8. You may not solicit any personal transaction (buy, sell, rent, trade, free, donate, etc.) in the forum. This includes solicitations for charitable and non-profit causes. Personal transactions arranged completely by Private Message are not affected by this rule. Solicitation by PM must be preceded by contact in the forum. Please note: threads or posts that give extensive details on anything that is for sale will be assumed to be an attempt to advertise and are subject to deletion. If you are selling a boat - paid advertising through iboats is acceptable to post in the forum. A link to the ad is mandatory and must be included in your post. Signature links for boats advertised on iboats are acceptable. We encourage members to use this service.
dazk14
Ensign
WIMUSKY
There is an issue, however. This thread is over 90days old and needs to die......
