I tried to start my 1988 Bayliner Capri and all it did was make a buzzing sound. Since battery is three years old I got a replacement. I put battery in and the dash equipment lights up and trim works but when I turn the key I get nothing. The gauges all work but when I turn key the bottom out and then return to normal position. I assume that is normal.
I doubled check to make sure the ground and positive cables were connected correctly, I assume it is no different than a car in that respect. But since I get nothing when I turn the key I assume perhaps fuse or something?
Can someone give me some basic troubleshooting help here as what to check. The boat had not been started in a couple of months. I am not sure why I am having this issue.
Thank you
Thank you
