Need carb kits for a 1968 an 65 Viking 3.5 hp air cooled motor
garyq
Also I read people taking about soaking carbs in a can of carb cleaner ? where do you buy a big can like that I can,t find it any where ,but can find engine cleaner in jugs !! and anyone know where to find coils and condensers and points for a 1955 Gale 22 hp E-start Sea KING made for Montgomery Ward ;)IMG_0102.jpg model #34801
serial # 2601 thats for the one in the pic 1968 yr 1965 model # 34501 serial # 1325C hope one of you know where to get these parts just got a 14 foot aluminum canoe for these small motors and want to be ready for water
jerryjerry05
Re: Need carb kits for a 1968 an 65 Viking 3.5 hp air cooled motor
DON"T soak anything in a comercial soak.
It will ruin any plastic/rubber.Just use a can spray.
Then spray after that with WD-40.
Valley sales in Prudenville,Mi. (989) 366-8178
He specializes in the older Chryslers.
If you really want a soak,any Auto Zone,Murphy,etc. can get the 5gal can or the 1 gal will soak a small carb.
steelespike
The viking sure looks like a WestBend built motor.Also looks very similar to the Elgin built for Sears by West Bend.
West Bend was pruchased by Chrysler circa 1965 So those could have been built by Chrysler or rebadged.
The 22 Sea King is very close to an Evinrude/Johnson motor.
Gale was a devision of OMC. Ignition parts are the same. Routine ignition and fuel system parts are readily available
some right here at iboats under the Evinrude/Johnson listings.Motors built 57-60 Model number on mounting bracket begining with 22D.
garyq
thanks guys thats what I need to take this project to the next level ,so how do i get the fly wheel nut back on at 80 LBS when the wheel moves freely
rhinomacho
my manual for that engine says 25lbs and another spot to try for rdebuild kits and replacement carbs is discount marine i got a brand new carb for my 50hp viking i got there number from tillitson in ireland do you knwo where to get points and a condensor for your motor i have two of them and they both need points
