mercs4mark
- Joined
- Dec 19, 2010
- 141
Hi guys ....I was working on my alpha 1 and pulled the bearing carrier out to replace the seals. carrier came out relatively easy...problem is reverse gear and thrust washer is still in the housing, in other words I pulled the reverse gear right off the bearing, I assume the thrust washer is frozen to the housing. I have PB Blaster soaking on it right now, any ideas how to get this out, I cant get a slide hammer in and don't think you could get between the gear and washer anyway.
